So I bought a 30" Dell 4-5 months ago. I started having problems with it coming out of sleep mode. I got it exchanged but stressed that I wanted a brand new one and not a used one.The Dell guy said he could not do that so I ended up speaking with the supervisor who said it would be perfect like a new one but if there were any more problems then he would definitely replace with a brand new one. The replacement arrived pronto and looked brand new to me.
Fast forward one month and the replacement has 3-4 dead pixels now plus after warming up it makes a CLACK noise and the top right hand corner of the front panel develops 2-3 mm play if I press with my finger. It's as if the heat makes it expand or something. It sounds worse than it is but still...
Is this ground enough for me to ask for another replacement? I have 5 year warranty on it. Thanks for any advice
EDIT- So in full black screen I see 3-4 tiny but clear ones. If I look more carefully then there appear to be bunch of very tiny and less obvious/less bright dead pixels in various other parts of the screen...15+. I don't know what the difference between the two sets of dead pixels is?
