mista ting
- Apr 13, 2006
^^how much of a difference would it make if i apply better GPU thermal paste on the 7950? what results could i expect? 3-5c? or more? would it be worth the hassle?
Is this answer directed at me? I was asking about the accelero xtreme
I dunno, my card gets quite hot. At 1112mV I can support 1215mhz. But not for long. The core clock is abou 75 degrees and fan is at ~80%. VRM (the hotter one) is at 80 degrees and slowly rising to 90 plus. At 80% the fan is too loud for my liking.
And why are lower voltages harder to cool on some cards? Makes no sense to me. I am pushing 1215mhz on ~1.1v and I can barely cool it. I can cool 1100mhz at 1070mV handily enough, though. Other people are getting same or even slightly lower overclocks, but they new much higher voltages (like 1.2/1.25). There's no way I can cool anything above 1.12v. I don't NEED TO (because 1.12 pushes 1215mhz) but can people explain why some cards need lower voltages but push out more heat for those voltages?
The DualX cooler is already very good and i dont think the Accelero will give you much better cooling. You could purchase one of those PCI slot blower fans to excel heat directly from the card. The goal is to exaust the heat and not push it around the case heating up other components.
You are assuming that your GPU can handle 1.3v and a high clockrate, my assumption is you have a high ASIC, you may not be able to get there. It wont be a limit by the temps either, just the chip itself.Hmm. That doesn't explain why some cards have a stock voltage that's way higher than even my overclock voltage, and can cool it. The thing is, if I have sooo much voltage headroom, I can overvolt to 1.3v safely (maybe a bit less) which would probably put me at 1350mhz which is insane. But I can only cool 1.1v as it stands so that's not going to happen.
On air, absolutely. If you want to achieve a higher oc, tahiti is even better under water.Amazing cooler and will get you the best clocks.
Anyone have any benches of VRMs at high voltages? It seems core temps seem well in check
Thanks a lot man. Those numbers are very relevant, and inspiring too do you mind me asking what your ASIC score is?
Where did you get those copper heatsinks? How much? How much of a difference do you think they make vs standard (aluminium?) ones?
Sorry, should have looked.
Hmmm. That comment scares me a little bit, about the VRM
In any case, the VRMs are fine even at 90 degrees (or higher even) based on what I've read.
I hope I can get those in the EU. The thermal tape is only 75cents delivered worldwide, 7 dollars for the tape. For what do I use that? Doesn't glue come with the Arctic gear?
By the way, is part of your PCB and PCI connector at the very bottom burnt, or is that just the light?
Eh, can't say I'm a fan of the included thermal glue that Arctic uses. Looked like it was nice and secure, held for a few months, then one day I'm blowing out dust and three RAMsinks and one VRM heatsink fly off the cardThe glue that Arctic gives out with the Accelero is very good and comes off easily when you are done or need to RMA......you just have to follow the directions to a "T".
Yup, that's what I used to replace the failed Arctic thermal adhesive. Just make sure you get "Arctic Alumina Thermal Adhesive," NOT "Arctic Silver Thermal Adhesive"Arctic epoxy is also very very good, but very very permanent
