sabregen
- Jun 6, 2005
I just recently made a purchase that has become the bane of my existence. I don't even have it yet, but have spent most of the weekend researching compatible components, and spec'ing out my new build. I have looked and looked...Newegg's HSF section is a damned nightmare to navigate unless you know exactly what you're looking for (my complaint centers around the fact that their socket compatibility matrix choices on the left hand side are ridiculous, probably rarely updated, and inconsistent).
Thanks for any that can lend a hand. I've been scouring all weekend on a board that would support those chips, where to get what, and looking for deals. I think I need to hand this one off to others that might know better than I. I've had about 10 machines over the last 3 years, and they've all ran Zalmans. It was never a problem before, but I've gotten a little sick of the noise they bring to the table.
Preemptive information dump on the usage:
This board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131141
These CPUs: http://www.hardforum.com/showthread.php?t=1352090
16GB of this: http://www.newegg.com/Product/Product.aspx?Item=N82E16820134622
8 of these in RAID-0: http://193.128.183.41/home/v3__product.asp?pid=502&inf=fsp&wg=83
6 of these in RAID-5: http://www.geeks.com/details.asp?in...aily_html-_-24sep08_21R-_-BannerST3750330AS-R
Running this: http://www.vmware.com/products/esxi/
Here's what I could use some help with, and need in a new HSF choice:
* Not a Zalman (I love them, really, I do, but the noise of late has driven me away from them)
* AM2 compatible 3.5" offset between latches (this is normal spec for AM2)
* latch attachment system for AM2 type mounting
* CANNOT use screws to go through the board into a backplate
* something relatively quiet
* PWM functionality based on CPU heat output
* Copper construction, or at least the base...okay mostly copper will suffice
* Would be great if it was rated to tackle Phenom quads, which are much higher wattage than my chips, will give me plenty of OC room (yes...OC 8 cores)
* Under $50...at least under $60 (I'm going to need 2 of them, so cost is a concern)
