Some basic questions:
1. Is short stroking via way of partition simply partitioning off the outer area of the platter of a disc(s) by making it the first partition?
2. When short stroking 2 discs in raid, can the remaining space be partitioned into a storage drive? 3
3. If (2) is possible, will the initial partition of the short stroked drive have faster performance than the second partition, even though both belong to the same set of physical HDD's?
Thank you much for your replies.
