Shorting Question
sdk
Well I took my mobo tray out, with my motherboard and all the stuff that is usualy on it, and took it out as I am gonna mod my case, one of my speak cables that plug into my sound card hit my tray and the speakers made the noise, this has happened before but while the comp was on, this time it was off.
Should I be worried about anything?
unless you applied current to the speakers i think they should be fine. the only way to know is to try them out.
yeaha I did, it works
but jesus, as I was putting it back together, and on the 2nd test boot, wheN i was taking pics, i moved my rock switch, and the heatstink came off enough so metal to metal touched, and it shorted out, gave me quit a scare
