I want to upgrade the CPU in my Precision T3500 to a W3680 and then take advantage of the unlocked multiplier.. I know that the Dell uses spring tensioned screws but I'm pretty sure the spacing is the same and I can probably rob the screws and springs from the stock cooler, and with a couple washers make it work with an aftermarket.
What is the most compact cooler that can do this job? Failing that, I know that the XPS 9100 cooler will fit directly also using the same spring bolts, but I'm not sure if it's too tall, or whatnot.
