Shorter or right-angled *internal* USB connectors?
Posted this on another forum as well...hope there are some ideas about this. I'm sure everyone here is familiar with cramming a lot of stuff into a small space, so I think ppl have to have run into this same issue before...
Basically on my mATX board having a 2nd graphics card installed in my last slot has effectively blocked all my internal USB headers except one. Because of the heatsink (passive 5450) on the card, there's no way to have the card inserted and the front panel/internal USB headers plugged in at the same time (this also goes for the Firewire connector but don't really care 'cause I never use that and there's a port on the back anyway). I just changed my motherboard in this case just recently and on the old board I could at least get to a couple of the USB headers which was enough. On the new one, no dice.
So... I need either shorter internal USB connectors to plug into the headers, or, right-angled ones. Searched everywhere and came up with nothing. Either that or I'm gonna have to remove the HS on the card and have at it with a Dremel or grinder, lol. The card is only used for audio and therefore stays at idle most of the time; I have the max clock restricted as well so it'll never run at even stock upclock at any time so I don't think cutting a small part of the HS will matter.
Anyone ever run into this problem and/or have a solution? I actually only need two more ports (one header) but I guess what I could do is get the USB 3.0 upgrade board for my front ports and then run an internal to external cable to the rear USB ports on the outside (I did this with my SG06 mITX box but it came with USB 3.0 panel ports). Hmmm...
oh man, that would be great
seems like a right angle could be made in about 2mm over the end of the pins
subbed
One possibility is you can pull off the plastic housing around or below the USB connector pins. This way the connector on the cable will actually sit a couple mm lower.
That would actually work...if it were available as USB 2.0 and Firewire as well. I don't get why no such thing is made/on the market. I mean even all the China sellers on eBay that sell every kind of adapter, connector, cable you can think of, don't have something like this :confused:
Interesting idea though it doesn't seem like those connectors are exactly easy to come off the board? They must be glued or fused to the pins I'm imagining (which are soldered to the board), no? Has anyone ever had success removing one of the base/shrouds off one of these?
I wouldn't have mentioned it if they don't come off. ;)
I've pulled them off (carefully) using slotted screwdrivers and pliers. Just be careful not to scratch the PCB.They are usually held on by only the pins. I think they are designed so the holes in the plastic are a hair smaller than the pins, and they are just press fitted together.
The most recent time I removed one inadvertently. It was a USB 3.0 connector on a motherboard I was removing from a case. When I pulled the cable out, the connector housing came out with it and stayed on the cable.
Ahh, I see. Okay I'll give that a shot--see if that works! If it does it'll at least tide me over until I get the USB 3.0 ports for my case.
