Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How do you reattatch the metal clips (the things with the barbs that fit into the plastic piece) and remove them correctly? I want to shorten my cables, but cant find out how to put the metal guys back on. Do i need a special tool?
i can get the wires out of the plastic, but then if i cut them i lose the metal plugs that are on the ends. Is there a way to remove those plugs and put the on the shortened wire, or put new ones on?
