Pagefiles are mostly very small read/writes, which means you want it where it has the smallest access time. In this case it would be the C: partition.I have a short stroked raptor 450gb which partition is the best location for pagefile?
Also, since you are using a mechanical drive, you should set the pagefile to a static size. I see your sig shows 4GB of memory, so a 4096 MB static page file would be great. I would not go less than this since 4GB can fill up quick on certain things and you need some good spill over space for the OS to page to if necessary.
