Need some advice from you guys on what you think the best user friendly shopping cart thats out there, try keep it under 700 bux tho Thx for any advice
oscommerce or it's offshoot Zen Cart.
Both well under 700 at 0 & 0.
Both able to be modified with little effort.
Zen Cart is highly modified from the start.
I'd have to say OSCommerce too, not only can it be obtained and used for free (and it's open source), but it has a rather large community behind it too.
I'd say OS Commerce too. I made my own using ASP.NET 2.0 but OS Commerce saves you alot of headaches of security and there are tons of pre-made templates for an OS Commerce site and you can easily get rid of the canned site look.
