Shipping a computer: Need advice
have2p
I have to ship a computer to my friend. I have built a lot of computers, but never shipped one before.
I was thinking I would just put the case back in the box/packaging it came in. There are two large styrofoam blocks on each end. If the empty case can ship safely, can't the computer?
Are cardkeepers necessary?
Should I put any additional packaging inside, like bubble wrap?
Should I do anything internally to prevent stuff from popping out or getting damaged?
If anyone has any experience in shipping PCs, I could use some guidance.
Thanks.
I think if you shipped with the case box that came with and the styrofoam you should be fine.
That is if you dont have a super heavy heatsink on your mobo. Make sure you tell them its fragile and pray they dont throw it on the truck
Be sure to insure the package for its full value. Though I'm not sure if they've ever actually paid out for an insured and damaged package.
Put it back in the original case box, insure it and send it via FedEx. If the heatsink is held on with only a clip you may want to detach it. We used to sell retail machines at work and the most common issue was always the heatsink getting knocked off in shipping.
Yeah the heatsink is just a stock AMD HSF that clips on, but the clipping mechanism seems really reliable. I also zip-tied both ends of the heatsink to the mobo and tightened the screws that hold the plastic retension mount.
