dariuslatamus
- Mar 12, 2005
Hi guys,
I'm just wondering if anyone else with a 2405fpw has experienced this sort of shimmering effect that you see on certain colors. It's almost as if the colour is vibrating or similiar to when you are running a CRT at 60hz and you notice that it's so bright that it seems like it's vibrating. I usually see it happen on grey colors but I've also seen it happen on some other colors as well. It's not a very strong shimmering, in fact, you won't even notice it until you really look at it. Mostly on the left side of my screen.
Can someone tell me if this is something that usually happens with LCD's or if it's some sort of defect because this is my first LCD I've ever owned so I'm not sure if this is normal or not. It's not that big of an issue currently, but, would this sort of thing get worse as I go? I don't want to let it go too long because if I have the oppurtunity to get a replacement now I would prefer that.
If it is a defect, I would presume Dell would send me a replacement due to this reason alone, no?
Thanks,
Darius
Thanks,
Darius
