Shielded AC Cables, Line Conditioners, & Voltage Stabilizers...
I know there was a thread talking about possible benefits to using higher-end DVI cables for LCD Monitors (ie. Monster Cable), but has anyone taken it to the next level and used such things as shielded AC cables, AC line conditioners, and AC voltage stabilizers?
I have done alot of research on these items, and it seems they would make a huge difference according to reviews. Yet...they are VERY VERY expensive. Since I am a fan of Monster Cable, I have mainly looked at their products.
So what do you all think?
FYI: This thread is on topic because these gadgets supposedly do effect video quality (displays)...as well as audio. I am mainly looking to hear first-hand experience of how they will make a display look better.
First off, Monster Cable is good... but not worth the money. There are better products out there for the money. Also, it won't make a huge difference but if you have interference problems it will help.
Personally, for my high end audio equipment I use hospital grade (green dot) power cords. They are cheap (only cost about ten bucks each) and they have excellent shielding.
Edit: These kinds of things affect audio much more than video, btw.
Where I work, I can get Monster Cable at cost :)
Lets just say cost is waaaaay below retail price!
Can you post some links to other cables that have better price/performance ratio?
Specifically which kind of cables? I am not exactly an expert in the video area stuff, it's more in audio that I know the brands pretty well.
edit: if you can get monster cable cheap, then do it. It's pretty good stuff, just way overpriced.
We have been down this road before, but the answer to your question is yes. All your questions that is.
You are right, it’s expensive, no question there. Cost benefit is always a personal issue of course, but I have 20 or so 2 gig plus computers (all AMD) all over clocked to the bleeding edge running distributed computing programs 24/7 and I use voltage stabilization and power filtering on all of them. And yes (let the flames begin) I use Monster products.
What have I gained? No blown PSU’s no spontaneous reboots, no blue screens of death, no hard drive failure (exception, 1 Maxtor but that has gone out 3 times and seems to be the nature of the beast) and no motherboard failure unless I pooched it. (Exception again, there was that bad batch of CAPS, which no one could avoid).
I also use the step up DVI cables on three of the systems I use for graphics and multimedia work. The visual difference is very plain and apparent.
We won’t even go into the two Hi Def home theater systems all of which use the same power filtering and stabilizing setups.
If this stuff didn’t work as advertised companies like Belkin (who makes junk) would not just now be entering into the higher end of this business. Monster was by no means the first, but dollar for dollar their stuff works and works well and they guarantee it for life. No questions asked. They also guarantee your equipment as well.
