She's a beaut
azul
A massive beauty, though. Didn't expect the CM 690 to be this big, but I guess my components really do need the space, and I'm comparing it to my previous case, which is a fair bit smaller. The Corsair 550 also has some really fat cables.
Seems to be working fine... just had some minor trouble hooking up the motherboard... formatting a partition right now. Heatsink instructions were terrible, but I got it eventually. I hate how I have to really brute-force all the toolless parts of the CM 690 to open/close... even managed to break off one of the little blue switches at the back when I put in the graphics card.
Here are the parts:
- Q6600
- G.SKILL F2-6400CL5D-2GBNQ PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-15 240PIN Dual Channel Memory Kit
- Samsung SH-S203B Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL 18X/12X INT DVD Writer OEM W/ Vista SW
- EVGA E-GEFORCE 8800GT Superclocked 650MHZ 512MB DDR3 PCI-E Dual DVI-I HDTV Out DIRECTX10 Video Card
- Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN
- Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM Fan
- Thermalright ULTIMA-90 6 Heatpipe Cooler LGA775 AM2 CPU Heatsink
- Seagate Barracuda 7200.11 3.5IN 500GB SATA2 8.5MS 7200RPM 32MB Cache NCQ Hard Drive
http://img247.imageshack.us/my.php?image=puterio4.jpg
Cables are a bit messy, but they're so thick that I don't think there's much I can do. Thanks a bunch to the people on hardforum.com for helping me choose my components. :)
Put your CPU Fan on the other side of the heatsink... for a push-pull effect with the case fan.
And please don't create anymore threads related to your build, lol. 3 is enough. Keep any new info/questions here. Thanks.
Oh, and thanks for the pic! :D
Tidy up them cables... use zip ties wherever you can to bundle as much as you can and hide/tuck any excess cable(s) away.
Hmm, I thought that pushing the hot air out the back would be best, but I'll give it a try.
I just got this case myself for my server. Can't beat the price....$40.
I agree with enginurd's suggestion. Move the fan to the other side, so it pushes air across the heatsink. After moving across the heatsink, the case fan in the back will suck out that hot air.
So the main sticker should face the back of the case, right?
nice build
how's the hdd? thinking of getting one of those :D
Not quite sure yet. Partitioning the hard drive took ages, like always:) I'll have to play with it for a few days before I can really tell, but I'll tell you then.
is you ram in the correct slots? usually they go in the same color slots 1&3 or 2&4. i know not all motherboards are like that but its always something to double check.
I wouldn't go by the sticker. You can easily tell by either arrows on the fan housing, or by looking at the blades to determine which direction it moves the air.
