ShellShocker: Linksys WAP54G $16
could i make this a wireless repeater? I don't see why i couldnt but wanted to check if someone has done it before
I picked one up -- need a legacy G network for the front of the house. It looks like it's fully DDWRT compatible too (huge plus!).
So would DD-WRT turn this into a router or still only WAP?
It would turn it into a fully functional router, although completely wireless given that it only has the one 10/100 port. However if you already have a switch laying around I guess that poses little problem.
Do be aware that although DD-WRT will run quite well on the WAP54G, actually getting it onto the little bastard can be a pain in the butt depending on the hardware version.
this is not a router, as it doesnt do DHCP or other routing functions (not sure if it does NAT or not, probably not). this is an access point, and yes you can load DDWRT.
for some reason the deal is still going on past the end time. i guess they have a lot ;) i picked up 4 for myself.
.....aaaaand once you load DD-WRT it can do DHCP and everything else.
