Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Um... Well, the place where I got a nice sheet of aluminum happened to be in Oakville... just off of Spears road. For you, that's literally a 45minute drive (Although you can walk to the place in 10minutes from the Oakville GO station)...
Like I always say .... your best bet is to check your local listings for welding or sheet metal shops in your area. If they cannot help you chances are they will gladly point you in the right direction if you ask. I'm a metal eater from way back & that is where all my materials come from.
