SHARP AQUOS Black 32" 16:9 6ms LCD
Wow, that's quite a nice LCD. It's making me think about canceling my Syncmaster 275T order.
Why would you cancel your 275t? Unless you're planning on using your monitor more or less as a Television instead for general computer usage. Even on the 275t, you notice the effects of a higher pixel pitch. Imagine how much more on a screen that has 5" more inches yet lower resolution.
Unless you only care about using it as an entertainment screen, don't bother imo.
The Sharp is 1920x1080 and the 275T is 1920x1200 so the difference is minimal. Whichever set I get will be used as my primary PC monitor. Plenty of people are very happy with the 37" Westy as their monitor. I'm in a similar situation as the OP. I have a 24" Dell 2407, but want something bigger. The 275T and Sharp are within $100, but the Sharp seems to offer a lot more bang for the buck.
The difference may be minimal on the resolution scale, but the sharp tv adds 5 more inches hence raising the pixel pitch from 0.303mm to approximately 0.37mm.
For general pc usage I guess it shouldn't matter too much. But if you're into any sort of professional work, it will matter.
Well, just my opinion. Not saying either is better.
Oh I gotcha. Yeah I've been wondering about pixel pitch for a while now with these panels. I was thinking a 37 might be quite noticeable. I do the occasional photo editing so I might get pissed. :)
For the most part though I just want a multipurpose panel I can do all my media with. Think this is a good choice?
Hi All,
I have the Gaming Model the Aquos GP1U the only difference being lack of a DVI connector & Vyper Drive. I use it as my primary PC Monitor & it's great. I had a similar situation where I wanted to go to a larger display & had considered the offerings from Dell,HP & Samsung, however like you I felt the Sharp offered more bang for the buck so I went for it & am extremely happy that I did.
Hi All,
Thank you very much. :)
I just bought this LCD, but I returned it four days later. I thought it would be good for a primary monitor, but it was just too "gawdy" and too large for desktop use IMO.
"gawdy" in what sense? Cosmetic or screen quality?
Just as another opinion. I have the Westinghouse 37" LVM-37w3se and I do image/video editing (not professionally but I do have many years of experience) and I can definitely appreciate the larger screen size and higher dot pitch. Being able to make out individual pixels is important in graphics work, as is having a high resolution so there is a large amount of workspace and lots of pixel-level detail is visible at once. I sit about 3-3.5 feet from the screen so its not overwhelming (if you have to sit closer than 2-2.5 feet it will be) yet its just the right size for me. If you're using a 24 or 27" screen currently you're probably used to sitting closer than I do with my 37" screen. The Westy isn't the best at color reproduction and black levels so for some types of professional graphics work where color calibration/consistency is important it would not be suitable, but its probably better than the Sharp in those areas based on what I've read about the Sharp and my experience with the Westy.
Interesting. Thanks for your opinion. I have a 17" screen, lol. A 22" widescreen looks enormous in comparison to what I have. :p
I'm going to have to measure the distance the screen would sit from my face, I'm thinking 3 feet-ish.
This is the dilemma I was worried about. I may have to go to BB or something and see what I'm working with. I keep hearing issues with the SE revision of the 37, anyone know anything about that?
SE issues should be fixed if you get a NEW set (NewEgg has them new for $900).
Basically the first batch of SE's (notably those bought from Costco), have lots of problems getting them to run in 1080p, because they have the wrong EDID. Devices that rely on a proper EDID, such as the XBox 360, will be unable to select 1080p over DVI or HDMI. Same with PCs, but its possible to force 1080p with the video card's drivers. ATI cards apparantly do this without any fuss, but NVIDIA cards require some tweaking. A firmware update performed by Westinghouse fixed this and new sets have the updated firmware. So if you get a new set you should be good to go.
Is there anyway to check that at a retail store or something like that? Or maybe another online retailer has the panel that can be confirmed new like you said?
The reason is that TN residents are charged tax, which sucks. So take + shipping is close to 175 extra I think. I would rather either 1) pay shipping 2)go to a retailer and pay tax. However, I would pay the extra fee to ensure I get a new one.
Thanks again for all the replies guys, really helping me out.
I'll hafta make a run to BB or CC, tomorrow. I'll see if I can get a good look at the Sharp. I've seen the 275T several times, so my decision should be made by the end of Monday.
I may do the same my friend. Please do us a favor and tell us what you think. :) We can compare if I go.
I'd make sure you do some forum searches on the Sharp. The dynamic contrast setting isn't appropriate for text display and apparently cannot be turned off.
(As a whole package though, many are quite pleased with the Sharp...)
Count me as one of those quite pleased, and I'm a former Westy 37W1 owner.
At 32" it's the perfect size for my desk, a 37" would have been too big for my current space. It's also a good compromise with dot pitch. Refresh and response times are fine on this unit, no ghosting, no noticable input lag.
The dynamic contrast can't be totally defeated, but you can minimize the impact it has, and after a few days use I stopped noticing it. The only real downside is that bold red or blue text on black backgrounds is blurry (usually you only notice this with the inline ads on some forums, like the red ones [H]forums used to use.
The unit is very attractive, much more so than the Westy, it's just made of higher quality plastic and more tastefully finished.
And the prices on the unit have come down nicely, I didn't follow the Newegg link (bastards won't ship to Canada), but it's easily had for under $1000 these days.
Just keep in mind if you get one to visit monoprice.com and order a $5.00 DVI to HDMI cable, the 62u doesn't come with DVI inputs, but works just fine using a DVI/HDMI cable (or even an adaptor).
I just saw the Sharp at CC. It's a beautiful LCD. They didn't have it hooked up to a PC. In fact, the sales guy was quite surprised that I wanted to use it as a monitor. I'm not sure what you mean by "defeating the dynamic contrast." Can anyone clue me in about that? I do a lot of writing and editing, so text clarity is important. I haven't made up my mind whether to get the Sharp or just stick with the Syncmaster 275T.
Well, I just got home from watching a friend demo Team Fortress 2 and Portal on his Dell 2707WFP 27" LCD.
OMFG!!!!!!!!!!!!!!! :eek: :eek: :eek:
Everything looked incredible... smooth gameplay, brilliant colors, no ghosting. And he thinks the Syncmaster 275T is a better LCD. This experience sealed the deal for me. For MY needs: writing, editing, video production, gaming... the 275T is the LCD for me.
Don't short-sell the Sharp based on the 275t or 2707 results.
Text is good, it's just one condition that's only seen in forums with dark backgrounds and inline ads where it falls a bit short. I do an awful lot of document editing at home, and love it...it pains me to go back to the office and use a 24" monitor, let alone a 21".
5" of screen real-estate makes for a much more immersive gaming experience, and frankly, for a lot of text work, the larger text on the 32" is easier on most eyes, while still displaying a lot of information on screen at one time.
The Sharp also clobbers the Samsung on multi-media capability and don't forget you get a free OTA and digital TV tuner (complete with decent stereo speakers) with the Sharp, along with more inputs
May not be important now, but if you ever decide to retire the Samsung as your main display, it won't easily go into the bedroom or garage as a nice second HD-TV.
And at the current pricing on the Sharp units, it's a great bang for the buck...roughly the same price as the Samsung retail.
Hi Croak & JTM55. Could you post some pics of your Sharp LCDs? I'd love to see how they look when you're playing games and displaying documents. Thanks for your comments.
