Sharp 32" 1080P LCD TV - $599 @ Dell!
Wow..... that.... is somethign I want... but I can't afford to spend that right now... damn it!
Seems like a good catch though the avsforum link only goes to a sub-forum there and where I was waiting for a masterpiece review on it to make me want to buy it immediatly ;)
Supported computer resolutions:
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768
so does this mean that you cant run 1920x1080 on a pc??? :confused:
From what I understand, those are the available resolutions using VGA for this TV.
Using a DVI -> HDMI adapter should give you 1080P.
So would this be worth buying at that price?
Depends on what you'll be using it for BUT either way if you're gonna be using it as a TV or monitor you really need to research LCD TV's before you buy.
Do not buy blindly, nor take some noob's word for it. Roll up your sleeves, then plug the TV model number into the search bar over at the AVS forums and give it plenty of research time.
There's one thing i'm sure of, It's def a good deal on a good TV. The question is how good is it compared to it's competitors. All current LCD TV's will involve some compromise, It's up to you to research which compromise suits you best ;)
Ha! TVs only? That's called life.
argh, I should get this, but I'm a damn perfectionist and have to have the best so I'm going to spend 300$ more to get another 32" when I get the money woah shoot me
