brendank310
- Nov 10, 2005
i just recently bought the sharp lc-26d40u 26" lcd hdtv from bestbuy (more info here)
its main purpose is going to be a tv in a dorm room in the fall, but for the time being, i plan on using it as a pc monitor. i have it hooked up from my x700 pro on the dvi port to and hdmi port on the lcd. the problem im having is the resolution. its native resolution is 1366x768, and when i set it to 1360x768(closest ati drivers get to native), there is a flickering that appears. the flickering effect can be minimized by lowering the contrast all the way down and it isnt there on the resolution 1280x720(but an overscan which i cant seem to compensate for in anyway is.) The only other resolution that eliminates the overscan and the flickering is 1152x648, which is a little low for my taste. i'd really appreciate any help i can get on this.
