HisShatness
- Oct 24, 2005
Here is whats up....not using SFS when i right click a folder and go to properties there is no share tab.
Im running xp PRO SP3. This comp has been sharing folders for years now. This morning I got a chkdsk that I couldnt stop. Since then, I cant see the share tab.
Here is what I have done:
restarted comp
enabled and disabled simplefile sharing.
checked to see if file sharing turned in in network connections properties.
Checked running services like server and LAN one and both are on automatic.
Checked registry entires but most seemed to apply to the securitites tab.
used gpedit and checked local permissions.
Only thing I could do is a repair install......I have over 700GB of storage on my disks and I want to reinstall OS as a last resort.
Any Ideas?
restarted comp
Any Ideas?
