grogthegreat
- May 11, 2011
Sorry if this has been answered before but I tried searching on here and google!
So the initial goal is to get two ESXi hosts running off of a single shared pool of storage for as cheap as possible with great performance. I currently have a 36 bay Supermicro 837E16-RJBOD1 which has a built in 6Gb SAS expander.
The question:
Could I take two Dell ESXi servers and put a LSI 9285CV-8e raid card in each server and then connect both raid cards to a LSI SAS switch (LSI6160) and then connect the Supermicro case to the SAS switch as well? The switch would be configured so that both raid cards would see the same set (say 6) hard drives. I would have one raid card set the 6 drives into a raid array and then import the foreign configuration in the other raid card. Both servers would in theory see the same virtual drive on which I could put the VMware VMFS cluster file system which should prevent any issues with more than one server access the same virtual drive at the same time.
So would this work? In practice I know I'd want two SAS switches and the appropriate cabling for redundancy. I'd also get CacheCade Pro 2.0 on both raid cards and each raid card would need it's own group of SSDs as I know they couldn't share that.
In this setup I image that performance would be very very good and the cost is a lot lower than a iSCSI setup. Other than the obvious SAS cable length limitation, am I missing something here?
Thanks in advance!
The question:
Thanks in advance!
