shared folder/file permissions issue
jeffmoss26
We have a shared folder setup with a bunch of subfolders and html files (internal website) User has full permissions to the folder and subfolders, can create new documents in the folder, but can't save changes in the html files when edited with wordpad. It gives an error 'Access to (file) was denied' any thoughts?
The individual files do not sound like they are inheriting permissions from the parent folder. Check the permissions on the actual HTML file.
When you say permission are you talking share or ntfs? Share permissions may be read/write so you could create new files and edit them since created by that user but existing files may be restricted by the ntfs permissions
