ShadowPlay is not working | Taskbar issue with Nvidia Surround
Exor18
Hello everyone, I am not sure if this is right place to post. I have been having this problem since about a year and half. You can see my spec in the signature.
ShadowPlay is not working:
This was working on Windows 8.1 fresh install then stopped working later. I fresh installed Windows 10 and it is not working at all.
When I turn on the ShadowPlay, the icon showed red crossed line. I had the ShadowPlay set to Shadow & Manual.
I have tried turning off then on but no luck. I have also reinstalled Geforce Experience but no luck as well. Why is this happening? What can I do to fix this?
Taskbar issue with Nvidia Surround:
Note that this happens to both Windows 8.1 and Windows 10 fresh install.
When I set up nvidia surround, the taskbar went overlapping everything that are in borderless fullscreen.
Every time when UAC pops up, the taskbar will move from monitor to monitor. I tried to find a way to make it stop. I found by turning off the option "Confine the Taskbar to Single Display." This helped to stop it from moving around the monitors. Since I turned off that option, it will stretch across 3 monitors (nvidia surround) which I don't want. I do want to use that option so that it will stay in middle monitor of 3 monitors but if I do that it will overlap all games that are in borderless. I had no choice but to put it in 4th mointor, which is not part of nvidia surround. How can I fix this?
I have tried fresh install the driver but no luck so far. Please help. :(
