Sep 4, 2009 #1 S simonw n00b Joined Aug 7, 2009 Messages 46 http://www.cyberpowerpc.com/system/LAN_Mini-H2O/
Sep 4, 2009 #2 T timme Gawd Joined Jun 21, 2008 Messages 520 Inside photos would've been lovely. Is it the Corsair H50 kit?
Sep 4, 2009 #3 A akromatic Limp Gawd Joined Nov 17, 2007 Messages 220 it doesnt look like the H50 but its a asetec LCLC kit (makers of the H50) IMO the external fan = fugly they have enough space for internal fan
Sep 4, 2009 #4 S simonw n00b Joined Aug 7, 2009 Messages 46 timme said: Inside photos would've been lovely. Is it the Corsair H50 kit? Click to expand... At the bottom of the photo gallery, there is a downward arrow, you can click on that to see the inside of the case.
Sep 4, 2009 #5 I [Ion] [H]ard DCOTM February 2024 2FA Joined Jun 2, 2009 Messages 1,341 Nice idea, just not executed well. If only they had the fan internally... I might have to try this at some point with my SG05
Sep 4, 2009 #6 S simonw n00b Joined Aug 7, 2009 Messages 46 I'm guessing that an internal fan would get in the way of the optical and/or 3.5" drive cage.
Sep 4, 2009 #7 T timme Gawd Joined Jun 21, 2008 Messages 520 I would use a 2.5" HDD withouth the 3.5" cage and an optical drive. Then the cooling system should fit inside, without the ugly fan on the front.
Sep 4, 2009 #8 N NichoTL Gawd Joined Apr 15, 2008 Messages 772 If you put the fan inside, isn't the radiator in the way of the GTS250? (Maybe the solution is then to go for a smaller card like a 4850 or a 4770)
Sep 4, 2009 #9 J Jen 2[H]4U Joined May 26, 2000 Messages 2,177 you can see the length of video card will be a limitation as the radiator is there . to place fan inside looks possible if drive is moved somewhere else ? i would like to know cpu it is cooling and what temps it is under load. Jen
Sep 4, 2009 #10 S stevedave Supreme [H]ardness Joined Mar 6, 2007 Messages 5,737 You could fit the fan and the radiator in the case and also room for cooling the GPU too. Good but not great.
