ok, i had another thread about this set up a while back. i RMAd the case and everything started working fine for about a month.
now i have some new issues, that i have done everything i know how to do and i can not seem to figure it out.
my set up is :
SG05 Case
Zotac 9300 mobo
2gb ram
quad core 9400 intel 2.66mhz
nvidia 8900gtx 512mb
the story:
computer turned itself off one day for no reason.
i thought it was heat, so i took the cpu off and cleand it, and applied new paste.
put it back on, and the computer would not POST.
i removed the heat sync to see if that would make it POST and it did.
so i replaced the heat sync and it did not post again.
i loosened one bolt of the heat sync and it posted!?!
the computer ran for a few minutes and then turned it self off again.
i took everything out. cleaned the board, checked for burn marks or anything. found nothing.
put it all back in. computer did not post.
switched the RAM. the computer posted!?!
awesome.
turned it back on, it ran for a day with no issue. then crashed again.
now it will run randomly and turn it self off randomly. no clear interval. no relation to heat.
it does it with or without the GPU in it. it does it with two different sets of ram.
i am totally fed up, and im past the 30mark so i cant easily send things back. i could RMA things individually with their respective companies but i have no idea what is causing these issues. i have always built AMD machines in the past so i have no intel mobo's or CPUs laying around to swap out and test.
i would be willing to sell every part, but im not sure who would buy it as i can not guarantee the stability of this set up.
i just cant figure out whats wrong.
my set up is :
SG05 Case
Zotac 9300 mobo
2gb ram
the story:
awesome.
