SG05 mini-itx powerhouse
Spudsdude
Still a work in progress, but it is amazing what you can fit into an SG05
Corsiar H80i
ASUS Z87I-Deluxe w/4770k
Powercolor 7970 3gb
SFX Psu
I'm still getting the basic fit together, have an ODD, SSD, and Slim Laptop drive to stick in there yet (and the CPU which hasn't arrived yet).
The guy I am making it for is going from a HUGE Silverstone Raven to this build, so he should be pretty amazed as how much smaller it is.
Panasonic UJ260 bluray burner
Crucial m4 128gb
Might just be a 320 mini laptop drive with the SSD until I make a tray for under it to fit a few more. Might just use usb3 drives, unsure.
Why don't you put that in a cylincer like a PCB pipe and then mount fans at each ends, facing same direction. Then you created a wind tunnel. It will super cool that mini system if it gets hot.
