Hello All.
I have justI built a awesome SG05 build which is working great.
However my old stock CPU fan for my E8600 broke so I am using a old stock intel fan from my E6600. It is large and noizy so I wish to replace it (LGA775 right? under 78mm Height right?).
However I have never used a 3rd party CPU cooler yet. I was wondering could you give me suggestions on what I should get!
A) I am a total noob so I will need to knwo if I need to purchase other parts (most that I have seen dont seem to have the four pin connectors...do you have to buy feet for coolers seperatly? or do they clip onto the cpu or something?
B) I would prefer low noise rather then performance as I dont think I will overclock the computer. However I am willing to spend more for better performance incase I want a cpu cooler for overclocking down the road.
C) It would be great to get a cooler that has the fan on the side to help push out the hot air out the back of the case instead of a cooler with the fan on the top.
Here is the site I will prob get it from:
http://www.mwave.com.au/newAU/mwave...=sku_desc&SEARCH=SEARCH&Input.x=52&Input.y=11
So if you could have a look at that site and let me know what you recomend that would be great.
Thank you for your time!
