SG05 build idea
Dilzdo
I've been researching for some quite some time now (a year and a half...), and I'm ready to build a beastly ITX machine. Though, I have a few questions lingering in my head and I need some reassurance.
First, will the H80i fit in the SG05? I don't plan on having a drive so I can mount the rad vertical. I've read and seen H70's with push pull configuration fit but not one bit of information (or pictures) on the H80i. Can someone confirm it'll fit?
I plan on cutting out a piece of metal so I can fit a GTX 780 in the case and I know it'll fit (pics ;) ). But my main concern is, will there be contact between the GPU and the H80i? Again, I will be mounting vertical but just for reassurance I'm curious.
All suggestions and criticisms are welcome :) thank you in advance
