SG05 and a 4850/70/90?
jamesman32
I need to know what the most powerful graphics card the SG05's PSU can handle. I know it'll do the 4850, and the GTS 250 from Nvidia, but what about the 4870, and 4890? Some sites did reviews with the 4870, and it seemed to work. I'll be using a Zotac 9300-ITX, an E8200 for now, maybe a quad later, 4 GB of RAM, and a 3.5" SATA HDD. I don't want speculations. I need facts before I buy a new card, or stick with my 4850. Also, if the SG05 could support a higher end card, would I still have the ability to go with a quad later? I know I could get a 65w TDP quad, but those are expensive. Thanks
The cards you mention are a bit over the 9" limitation. Also, the power supply will not be able to handle the cards even if it did fit.
They will, there's 10.5 inches of space, but I guess if the PSU cant handle them, it doesn't make a difference.
If you use a graphics card that requires 2x 6-pin PCI-E plugs, then you'll most likely have trouble. The FSB power supply that comes with the SG05 has a 16A 12v rail dedicated to its single PCI-E plug and an 18A 12v rail for everything else. There is one line of 4-pin molex plugs and one line of SATA power plugs. You would at the very least have to dedicate the entire molex line to use for a PCI-E adapter to get the second plug. Even then there's still the issue with supplying enough power for the card.
That's just the power issue. When it comes to size, 9.5" would be about the biggest you could possibly fit in that case. That's allowing for room for cards such as the 48xx series that have the PCI-E plugs on the end of the card rather than on the side. My GTS 250 barely fit into the case so it's unlikely you'll fit anything more powerful into it unless it's a 4870, but since it needs 2 power connectors, we revert back to the original power problem.
Still though, a GTS 250 is by no means a slouch, especially the 1gb model. Unless you're going to be running at 1920x1200, this card pretty much handles everything that you can throw at it. I can run GTA4 nearly maxed out at 1600x1200 on this thing with no hitches at all.
Ahh, alright. I'm thinking I'll go with the GTS 250 at any rate. My 4850 runs way too hot, and the GTS 250 will be good because I can offload Phsyx to the onboard graphics.
Yeah, the GTS 250 runs very cool in this case. Mine idles at 34c and loads at 50c. Gotta love that big side vent. :D
