SG03 Side Panels
Spammy1984
I realize I initially asked this question in the wrong forum, I'm trying to find out if the two side panels on the SG03 are swappable. From what I can see in pictures of the case they appear to be I just wanted to double check with someone who had the case.
To clarify, I'm talking about the left and right panels, one of which has the large side vent. I realize that the vent is mostly useless on the other side, my plan is to replace that side panel all together.
Edit:
For some reason, I read "SG05" in the title.
No the side panels on the SG03 aren't swappable. The screw holes won't match up if you switch them around.
Yeah, looking at the back on pictures now I can see that. New holes can be made though so that is not too big a deal. From what I can tell it looks like they will attach to the other side its just the screw holes preventing it correct?
