SG03 & ATI 5870
Skott
I already know through search that the 5870 will fit in a SG03 case. I'll have to remove the bottom 120mm fan and either leave it out or add a 120mm slim fan. I'm thinking I'll add the slim fan because some cooling intake is better than none.
My question is to those that have added a 5870 to their SG03 cases is what kind of temps are they getting inside? Are you having any issues at all? What would you do differently if you did it again with a SG03?
I been contemplating going with a Eyefinity, 3x22" set up and thinking to get the card first and then when I get some more money buy either two or three new 22" LCDs. A new bigger case would be a better option but out of the question for now due to budget constraints and certain needs.
Rig in question is in my sig. Thanks in advance. :)
