SG01 Revision Hidden in Neweggs Database?
TheBlueChanell
I am trying to figure out which Sugo I want, be it SG01 or SG02 and while I was searching newegg I found This
New
Old
If you type in Sg01 only the 4 Evolution models pop the Black, Silver, Window, and Non-windowed models. If you type in "Sugo" it pops up but not the original sugo, and if you search Silverstone and narrow it down it isn't displayed in the mATX Desktop section. :confused:
It appears as if it's made of steel/aluminum as opposed to all aluminum. It also has the suffix of F. It has the same interior as the SG02-F and can accommodate larger GPU's. Anyways, anyone else seen this or have any info on it?
Other Silverstone Tidbits:
P.S The SG04 is also available. That may or may not have already been sated in the SG04 CES Thread.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163115
Performance-pc's has the all Aluminum SG02, but only in white.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=361&products_id=23388
Only thing on that case that is aluminum is the bezel. After building an SG02B-F for a friend last week, I am not impressed with the chassis. The SG01-BW is so much nicer to work with. The SG02W is nice because it uses the all aluminum chassis of the SG-01, I just don't like the power button location on either the steel or all aluminum version. The button kept getting stuck on the SG02B-F I built.
