SG-01 +NT06 +FX121 ?
Q-racy
Hi everybody,
i want to put my actual system into the SG-01,
A64 X2 3800+
MSI K8NGM2-FID
Geforce 7600 GT
Hitachi T7K250 SATA II
Enermax Liberty 400 Watt
So i want to use the NT06 semi-passiv solution, I think i read, that it is no problem for the X2.
Furthermore I am wondering, if the Silverstone FX121 Cross-Flow-Fan will fit, if you use the NT-06, or is there not enough space left? And is this additional Fan recommendable?
To get a silent system and because I'm just using one 5 1/4 Drive, I'm thinking of getting a HDD Silencer like the Scythe Quiet Drive or the mCubed Vertical Silence. Has anybody experience in using this kind of HDD Silencer in this case?
Anything else I should consider?
Thanks!
He's correct. the cross flow fan won't fit once you put the NT06 in. You might be able to add a pair of 40mm low profile fans in the back, but the Crossflow won't have enough room.
-E
