sup3rcarrx7
- Jun 6, 2010
Hi guys,
I just created a SFTP server on Ubuntu 16.04.1 LTS that will be accessed both internally and externally for file transfers from following the guide found at the Linod link below.
Limiting Access with SFTP Jails on Debian and Ubuntu <meta property=
There are 2 other issues I now need to resolve before I make it 'live' for actual usage.
Thanks in advance!
- How do i disable SSH access via putty, terminal, etc. both internally and externally?
- Is there a quick way to configure the ports on the system to only allow port 22 for SFTP and block all other ports?
- How do I make it so that when you log in with the SFTP account, it starts on a dedicated directory only. I don't want the system folders etc. to be shown.
Thanks in advance!
