SFF WC Case
[H]utch
Hi all,
I am looking for a SFF case to liquid cool. Right now I am considering either the Lian Li PC-V350 or the Lanbox Lite. I will also be possibly running 2 4870s, at least one for sure, so card length will need to be taken into account. Which one would be better to fit a watercooling system in in your opinion? With the Lanbox Lite you would have to side mount the radiator, which doesn't necessarily look bad.
The V350 has enough room for a slim 2x120mm radiator if you're going to use long cards. My 9800gtx+ is about 10.5 inches long and I don't think there is enough room to place a standard radiator between the fans and the card. I would say a radiator that is less than 20mm thick would work.
IMO anyone who has WC in this case is badass. I haven't really seen a bad setup yet.
But if you're going to cool two of those cards I don't think the radiator would be sufficient enough to keep the temps down. I could be wrong...
