Hey guys,
i am currently planing a new SFF system for a friend of mine.
She picked a Lian Li Q08 as her favorite case so i try to choose the hardware in a way that everything works together
Of course the most difficult questions is which air cooler fits into the case and on the motherboard without covering the PCIe slot and of course the ability to cool her i5-4570 good enough, with a little bit of "summer headroom"
From my research around the net the following air coolers are the top choices i got for the Q08:
- Noctua NH-C14 (Low Profile mode)
- Noctua NH-L12 (Low Profile Mode)
- Thermalright AXP-200
- Prolimatech Samuel 17
I would like to go with a GA-H87N because its affordable got integrated WLAN and as a little bonus is pretty much hackintosh ready
According to the Thermalright support page the AXP-200 fits onto the motherboard without covering the PCIe slot, can anybody here confirm that just to make that totally clear?
(http://www.thermalright.com/images/cooler/axp-200/mcl/GA-H87N-WIFI-b.jpg)
Another option i would like to consider is the ASRock H87M-ITX or the Asus H87I-Plus (C2) and here i would like to ask you guys if you think the Noctua NH-C14 would fit in low profile mode. According to Noctua it does but its always nice to hear about some actual experiences from users who tried to build it.
I hear different things about the AXP-200 with its stock cooler, do you guys think the cooler will suffice for a Haswell i5-4570?
Maybe you got other suggestions for the Q08, i am glad to hear about it.
Thank you in advance
Dennis
Dennis
