SFF Socket 478 or 775
kidicarus74
Well, I need a new computer for work, and I'd like to get a SFF (if i do, almost guaranteed it'll be a shuttle) and I can't decide what to go with. This machine probably won't ever be upgraded, won't need a fast video card, but probably will have a decent (not great, but not budget) processor (with hyperthreading). The computer will be used for 2d graphic design, web design, and software programming (.NET and database stuff).
Basically, what i'm asking is should i get a socket 478 (Northwood/Prescott) or would i be better off getting the 775. Will the 2.8 gHz 775 perform equally with a 3.0 gHz 478?
Any suggestions about anything for my comp, not just limited to the processor (suggestions about specific models/brands of sff's, ram, drives, etc.) are well appreciated.
Edit: I'm mostly asking cause I know intel is the way to go for digital media creation but all i've ever had in my many many years of computer building (and using) is AMD
get a intel 630. it is lga775 and is generally better and can overclock much better than the normal 775 prescotts.
if not that then a northwood 3.0 on the 478 socket. depends which barebone you get
To answer your direct question, a 3.0 northwood would pwn a 2.8 prescott, be it 478 or 755. It would probably pwn a 3.0 prescott too.
The northwood will also run cooler, something important the smaller your sff gets. no room for huge heatsinks in a shuttle.
