- May 5, 2006
I'm shopping for a bag for a Silverstone SG01 case. The case is 10.5 x 8.3 x 15.5 "
I listed a few bags/backpacks that look pretty good to me below. The 8.5" width vs 8.3" SG01 might be close on the jetpack and the sierra Passport, but I really like the design on those two especially. I actually would prefer the bag to not be oversized so it might work out better that way. The bag's extra 'piggy-back' compartments look like they might be big enough to hold a keyboard.
Trager Jetpack
17" x 21" x 8.5" vs SG01 case's 10.5" x 8.3"x 15.5"
High Sierra Passport
22" x 14" x 8.5" vs SG01 case's 10.5" x 8.3"x 15.5"
ebags: High Sierra Cove Island 24" Travel Duffel
12" x 24" x 12". vs SG01 case's 10.5" x 8.3"x 15.5"
- I wonder what the length of the main compartment is, since it has big side pockets as part of the dimensions..If the side pockets are 4" each, that would be 24" Length = 4" + 16" main + 4" . This would be cutting it close vs. 15.5" SG01 case length, if that guess is correct. (I have no idea). This might actually work out well with some padding for a good snug fit lengthwise.
- I'm not sure I'd use the pockets on the ends much. They might just be adding unecessary size/bulk to the bag.
I really like the jetpack but I'm not certain the SG01 case would fit in it since the 8.5" depth dimension might include piggy-back pocket width, while the SG01's height is 8.3". I'm pretty sure I could squeeze it in there though it would be bulging into the extra pocket's volume.
My other concern on some of the tighter fit bags is that I probably can't fit an lcd +protective sleeve in there, or any extra protective padding/foam. I want to be able to bring an LCD monitor along without a bulky stand. This means I would have to carry a briefcase of some sort along with the bag to house the monitor.
Overall I'd prefer a backpack or backpack hybrid if I can find one that will carry everything without it being in the 'mountaineering' range of backpack sizes. If I have to I will get a big dufflebag like the Sierra Cove.
Trager Jetpack
