SFF running Linux, for file-server, P2P and some HTPC
oakwood
Hi to all,
I would like to build an SFF small server, to have it "always on" in my living room, and to use it as file server and for peer to peer. Some movie playback (not really HTPC, just movies on a tv or monitor).
I want to run it under linux, because I want to learn it.
So, for me it will be also a "spare PC" on which experiment with the OS and new software.
I have been a mac user for decades. I have some experience with electronics, and I have serviced and repaired PCs (both Mac and non-Mac).
But I never built a pc from scratch.
Please advice me for a build, and possibly for online providers (I live in Canada).
Mainly, I would need advice about compatibility of hardware with linux (ubuntu) operative system.
In the following, my answers to the questionnaire:
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
Data storage & file server
P2P (emule, bittorrent)
Playback of movies (no super-fancy quality needed)
PC on which experiment with the OS and software​
2. Will you be overclocking? (If so, are you looking to watercool?)
NO​
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
$ 500
the budget is flexible
cost is not the driving factor in selection​
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
I live in Montreal
There is MB MicroBytes nearby​
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
motherboard
cpu
3.5" hard drive
case
ram
possibly a card with thunderbolt
possibly a graphic card, but I would prefer the GPU integrated on the motherboard​
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I have no parts to reuse​
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
*wanted* thunderbolt (but it is not a must)
*wanted* quiet
two USB 3.0 ports are ok. Four are better
I would like WiFi capability (but it is not a must)
size is not super important, as long as it stays below the "minitower" form factor
but if it fits in a backpack I would be happier​
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
no multiple monitor
no "extra high" resolution
I will run it without monitor most of the time (remote desktop), I may want to plug it to a TV to watch movies from time to time​
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
no need for optical drive
I will have it in a corner of the living loom, possibly close to the ADSL router​
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
moderately confortable with DIY
I have few screwdrivers, a Leatherman, and a digital (voltage, current) multimeter
I may look into buying a soldering iron (for electronics)
I wouldn't like to do too much work with things like sawing a metal frame​
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
quiet is a desired feature, since I would have it running 24/7​
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
portability is a desired feature
but as long as it can be carried around easily in a (big-ish) bag, it is fine
but if I manage to fit it into a backpack I would be happier!​
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I would use linux​
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
In a couple of weeks​
Thank you to anyone who will help!
