Dec 10, 2006 #1 A AMDXP 2[H]4U Joined Jul 9, 2004 Messages 2,631 Can you change the PSUs on SFF? Do any power supplies work? Or do you need special ones? Thanks!
Dec 10, 2006 #2 D doa n00b Joined Dec 2, 2006 Messages 15 Depends on the case as to wether you can put a standard PSU in - Microfly, for example takes a standard PSU. But yes you can always change PSU.
Dec 11, 2006 #3 N niranjan162 Limp Gawd Joined Jul 22, 2005 Messages 153 its a good idea to get a short DVD drive if your gonna be changing the psu
Dec 11, 2006 #4 D doa n00b Joined Dec 2, 2006 Messages 15 Saving space is always a good idea in a SFF case. If you are building a SFF then take note of the measurements of the components, in this case the PSU and DVD to make sure that they will fit. With a standard PSU the cable management with always be a bit of a pain as the power cables are longer than is needed for a SFF case.
