SFF Noob here...looking to build my first computer
mikeczyz
hey gang, I am looking to put together a computer. I figure it'll be a fun project for the summer while I'm away from school.
My budget is sub 1500. No monitor needed, will re-use the old one from current computer.
Mobo: Asus P5B-VM
Intel Core 2 Duo E6420
2 gigs of generic ram
8800GTS 320MB
case: SILVERSTONE SST-SG01-B
Seasonic 550W power supply
320 gig hd
dvd burner
how's it look? how hard is it to put these things together? I'm not a complete idiot, but i'm not a tech head, either.
what about cpu cooling?
will that mobo allow me to overclock my cpu?
i'm coming in right around my budget. any advice on how to cut corners regarding price?
thanks,
mike
Looks decent. Looks very decent even.
Something I would want to note though is the fact that you may want to check the clearance of the PSU inside of a SG01 case. I dont have a SG01 case personally, but a lot of cases cant fit longer PSU's. Now, you could just go with a Silverstone Element (ST50EF-PLUS Short Cable Edition) and shave off about 40 bucks from your PSU. Its a very solid PSU (36 combined Amps on 2 12v rails) and arguably one of the most efficient PSU's on the market.
Probably the best choice for a cpu cooler in that case is the SilverStone NT06 Lite. Its designed to sit against the bottom fan of the PSU (which is located right over your cpu) and use the PSU's fan to cool the heatsink.
As for overclockability? I cant really say that much. I'm not a huge OC'er. Really the best way to cut corners is go with an EVGA 8800 (because they are very very cheap, and have a rather decent warranty) and the PSU I mentioned above.
Hope it helps!
Looks nice. I recently did a build like it--SG01e, 8800GTS 640, E6600 so here is my advice.
The NT06 is a great cooler designed for that case. The NT06 Lite if you can find it saves a few bucks since you won't need the fan which is the only difference.
The only power supply you might have trouble with is the Hiper R series with those extra long jacks sticking out the back. The key is get a short DVD burner to maximize your clearance. The 20X Lite-On is an excellent drive. It's fast, SATA, lightscribe, and short giving you lots of clearance for your PSU. It also comes with a spare white front panel in the box that I think looks better on aluminum cases.
For PSU, consider a MODULAR power supply to minimize wires and maximize cooling. Modular is a new trend and maybe in a few years all of the good ones will be modular. If you are going for a quality supply, check the Tiered PSU Listings to see how your choice stacks up and what to avoid.
Mobo: Asus P5B-VM
A note about that board, it has no PCI-E lock. This means you'll have to raise your PCI-E frequency along with the FSB. At 120+ MHz PCI-E frequency most systems become unstable, and you run the risk of frying your graphics card, screwin' up the LAN, ect. The majority opinion seems to be that 110 MHz is the max stable operation for the PCI-E speed, however, I'm not sure if that's stable.
What does this mean to you? Your board will probably max out around 300 FSB, which equates to 300x8 = 2.4GHz for your E6420 (obviously not the max this processor can go). If you're satisfied with this overclock, this board may work for you, but I personally wouldn't be comfortable with my PCI-E running out of spec 24/7.
If you're going to be overclocking with C2D, the Fatal1ty FI90-HD seems to be your best option. Unfortunately, its got its own problems. However, I'll take its problems before I'd attempt to overclock with a shitty PCI-E lock.
Here's some reading on overclocking the P5B-VM.
http://www.hardforum.com/showthread.php?t=1114370
http://www.hardforum.com/showthread.php?t=1101150
This thread is a bit angsty, but it still gets the point across.
A note on RAM. DDR2 667 will suffice for just about any mATX overclocking on C2D, since there's no board on the market that goes much farther than 333MHz FSB.
Also if you're overclocking mATX, you're going to need a CPU with a higher multiplier, since you can't reach huge FSB's. The E4300, E4400, and E6600 seem to be the most popular choices.
go with a f-i90hd, mines stable at 2.45ghz and can do more, its at 320 fsb. but from sffstore.com
thanks everyone,
a few questions...do i really need a 500w power supply? it's not like i'm gonna go sli anytime soon so i keep thinking it's a bit extreme.
thanks for the reminder about the pci lock. my current mobo doesn't have an agp lock and i should've learned my lesson but apparently didn't.
i'll look into both the mobo recommendation and cpu.
one other question, i hear heat is the biggest problem with these sff systems. will i be okay with a cooler on the cpu and the basic couple of fans?
