SFF: No dual channel RAM?
bsmack
Is this one of the things they took out to make space? I notice that all of the SFF barebone systems I have been looking at don't offer dual channel RAM. Wouldn't this be a big performance hit? Are any of the manufacturers out there working on getting dual channel RAM into these systems?
Dual channel memory has always been made out to be a much bigger deal than it really is. With limited PCB space, mainboard manufacturers have to decide between a marginal to small performance hit, or a reduction in features. It seems that features sell better than performance, and with good reason, but that's what happens when the market demands more (performance and features) from less (space).
Um....lots of shuttles have dual channel ram....SN95G5, SB95P, Sn25P.....
I was looking at the SN25P on newegg, and it looks like there are only 2 slots for RAM. It doesn't mention that the mobo is dual channel anywhere in the features either.
You need to read around the forums a bit... you seem headed toward disaster.
The type of northbridge the shuttle-sized SFF uses will tell you whether it supports dual channel ram.
...and the difference between DC & SC is between 0-5%. Don't concern yourself with that.
Two slots is all you need for dual channel :)
It has dual channel memory, the sn25P at least. I have it and my memory runs at 260 x 10 = around 6900 points in sandra... its dual baby! :)
Alright, thanks for confirming that it did. I couldn't find dual channel listed under any of the features for the SN25P.
