Hi! I'm looking to supplement my current power-thirsty gaming rig with a second slimmed-down machine to run 24/7. I've built a few rigs before but they've all been ATX form factor. I'm a complete newbie to the world of building smaller things.
I'm looking for something like a Mac Mini, but probably much less powerful. Help appreciated!
Obligatory question-and-answer section follows:
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
IRC, torrenting. I can probably get away with running this as a headless machine that I only interact with over ssh.
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
A Mac Mini would cost $600 + tax and shipping and be overkill for this, so anything cheaper than that would be good.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Canada. I usually order from newegg.ca but am open to other retailers.
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, RAM, motherboard, power supply, some sort of internal storage (for the OS; I'll use a NAS for storing all my media), case.
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
Nothing except the peripherals I'll need to bootstrap the build (generic USB 2.0 keyboard and mouse, Dell U3011 display). No, I don't want this system to actually be able to push 2560x1600 to the U3011. VGA is fine.
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
I don't need anything fancy here beyond onboard video and GigE LAN.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
I'm going to run this headless, so I don't need any video output at all beyond what's required for initial setup.
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
I'd like to make this small enough to sit on the corner of my desk, but there aren't any strict space requirements.
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I've never done any case modding before and don't have any of these tools.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
I don't mind a bit of noise but would prefer something that isn't extremely loud.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Doesn't need to be mobile at all. It will live on my desk.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I'll be installing Ubuntu.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
Before the end of the month.
