I started a thread on the HTPC forum for a mATX build I was planning on building, but never really considered the mITX route until the creator of the sticky with the questions below pointed out his setup. Now I'm actually very interested in a mITX build considering SFF is my main priority now, I did have some questions about the build tho...
1. What will you be doing with this PC?
It will strictly be a WMC HTPC with cable TV tuning capabilities.
2. What's your budget?
I'd like to keep the budget near $400, but it's a little flexible.
3. Where do you live?
I live in BFE Oklahoma so I don't have any places nearby for parts.
4. What exact parts do you need for that budget?
I need: CPU, Mobo, RAM, SSD, Case, PSU, and possibly a slimline ODD. I plan on using a Ceton InifiniTV 4 tuner but I'm not factoring that into the budget goal above, just listing it in regards to case clearance concerns.
5. If reusing any parts, what parts will you be reusing?
I'm not reusing any parts.
6. What specific features do you need in a motherboard?
Needs:
HDMI out
Sata 6 Gb/s
Onboard video
Gigabit ethernet
Wants:
Optical audio out
7. What resolution output do you need?
1080p
8. Does this system need to fit into a particular space?
Needs to fit under a TV stand, there's plenty of room.
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have?
I'm comfortable with mods, although I don't really want to mod the case I have in mind. I have basic tools: screwdrivers, dremel, drill, bare hands, sledgehammer, jack-stands, nail clippers.
10. How important is the noise/silence of this sytem?
I want this bad boy as quiet as possible.
11. How mobile does this system need to be?
It doesn't need to be mobile.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS?
Yes, I have Win 7 Ultimate x64
13. When do you plan on building/buying the PC?
In a couple of weeks.
Here's what I have in mind, and I will buy used if possible:
Intel Core i3 2105
Crucial m4 64gb SSD
Foxconn H67S mITX Mobo
Wesena ITX7-B case
Ceton InfiniTV 4 PCIx1 card (if it fits) or usb version.
Possibilities:
Any cheap 2 x 2gb DDR3 1333 Dual channel 240 pin RAM
Slimline slot-load combo ODD
Pico DC to DC power supply
Any low pro HSF
My main questions/concerns here are with clearance with the HSF, Ceton card, and wattage requirements with the power supply.
I used a wattage calculator to see how much juice I would need, and I'm coming up with figures around 200w. Most pico psu's I'm finding are 150 max so I'm not sure if this figure is accurate, I see people with similar builds using pico 90's or so.
Any help is appreciated!
Needs:
HDMI out
Sata 6 Gb/s
Onboard video
Gigabit ethernet
Wants:
Optical audio out
1080p
Intel Core i3 2105
Crucial m4 64gb SSD
Wesena ITX7-B case
Possibilities:
Any low pro HSF
