SFF (mini/micro) eATX case?
Dark Prodigy
Jawbreaker
I'm wondering if there are any SFF cases, preferably mini/micro (non q-pack type) cases that accepts the bigger eATX type motherboard (Tyan Thunder K8WE or SuperMicro HDCP type mobo's). Looking into a multiprocessor build, but would like a case like the Lian Li V600 or Sliverstone TJ08.
Any suggestions or something I might not know about? Thanks.
Your looking for a mini or micro ATX case that will fit an extended ATX motherboard? Not going to happen.
The smallest you'll be able to find would be a mid-tower; somthing like the Lian-Li PC-7 might fit an eATX board (you would have to check the size of the board to be sure though).
eATX motherboards are not SFF, just like ATX isnt. even if there was a case, its not an SFF.
Yeah... taht would make it like, a BFF? or an MFF? Big Form Factor? Medium Form Factor?
I wouldn't consider 13inches Small Form Factor...
[H]owever, I would like to see you design your own "SFF eatx" case...
Ok then... what do you consider micro/mini type cases like the Lian Li G50 and the V600? They are able to accept a full ATX mobo but are no where near mid-tower size...just not eATX.
