Hi guys,
I'm looking to start a project build, which will most likely be bought from a friend. Basically the main goal is, to have the most portable case that can handle water cooling. We'd like to go with a small form factor case, but there isn't many cases in the market that even with modding (cutting panels, anything) that handle a water cooling setup well. I'd be open to go with a micro atx case, since they are smaller. Of a small atx case, if not too large. There is a budget for the case, being under 120$ would be stellar.
Also, it probably won't be housing a large radiator either. The CPU will be the only thing water cooled in this build. I'm finally asking here, because I've been googling for about two weeks now and just can't really turn up anything promising.
Side note, for whatever reason. I'd love to see a mini itx water cooled. Just because.
