SFF - Gaming Build
drklu
Hello all, here are my preliminary plans for my upcoming SFF gaming build (pending product release and funding).
Gaming
$2500 give or take. I'm hoping to save some money by using [H], ebay, craiglist, ext. to purchase components.
Gresham Oregon, USA
Case, motherboard, ram, graphics card, cpu, case, fans, closed loop water cooler (or components for a custom loop depending), water blocks, pumps, reservoir and NFF SSD.
1920x1080 23" Samsung
6) Will you be overclocking?
Yes
1 existing - 1920x1080 23" and hopefully a 2560x1440 Taiwanese monitor (yet to decide which)
2-3 months depending on the release of the Ncase M1 and the Asus Impact Motherboard.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
1 PCI-E, USB 3, Sata 6Gb/s
Windows 7 64-bit
Here is my preliminary build.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU/Mobo Block: EK full cover block
CPU Cooler: Swiftech H220 55.0 CFM Liquid CPU Cooler
Memory: G.Skill Trident X Series 8GB (2 x 4GB) DDR3-2666 Memory
Video Card: EVGA GeForce GTX 780 3GB Video Card
Video Card Block: EVGA full cover
Case Fans: 4xCougar Dual-X 64.4 CFM 120mm Fan
Power Supply: Silverstone Strider Gold 450W 80 PLUS Gold Certified SFX12V
SSD: NFF SSD
Case: NCase M1
Monitor: QNIX QX2710 LED Evolution
Motherboard: Asus Impact 1150 Motherboard
Keyboard: Ducky DK9087S2 Shine II Wired Standard Keyboard (open to suggestions)
Mouse: Mad Catz R.A.T. 9 Wireless Laser Mouse
Tubing: Anything that doesn't fog or plasticize
Fittings: Bitspower (probably go for smaller tubing/fittings sizes due to space constraints)
I may need to find a different cooling solution besides the H220 because of availability/cooling potential. My goal is to have a cool and quite m-itx pc that can run the latest games (Planetside 2, BF4, Total War Rome II, ext) at 2560x1440 with reasonable frames. I would also like to de-lid the 4670 for even cooler temperatures. The H220 (or custom loop) would be plumbed to both the graphics card and cpu and I plan to replace the existing fans with some with some that will perform better . I also heard news that EK will be releasing full cover water block (http://www.ekwb.com/news/364/19/New-water-blocks-for-ASUS-ROG-gear-in-the-works/) for the Impact that would be awesome in this build. I know some of these components aren't even released yet but I just wanted to discuss possible builds. In reality I'm just really excited for these upcoming components and want to discuss possibilities :D.
Any advice or suggestion would be greatly appreciated.
Best regards,
DrKlu
I don't need a internal optical drive. I can use a external one or none at all.
Does anyone have any suggestions for a pump/reservoir that would fit in the M1?
