bagelnagel
- Mar 2, 2013
1. What will you be doing with this PC?
2. Will you be overclocking?
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
7. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
8. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
Gaming - mostly console emulation, want to be able to get up to PS2/Wii/Gamecube and others that came before them, HTPC/Playback, watching TV via CableCARD
No
Sub $1,000, flexible, I think the video card will be most expensive, no?
Philadelphia/South Jersey, yes
- Case
- CPU
- Motherboard
- RAM
- Video Card
- HD
- Power Supply
- All-in-one cooling (preferred)
Not reusing parts
Would like USB 3.0, unsure if other features are going to be *required* for a PC that will be used for TV
1080p for TV
I would like to have this system fit into a particular space, don't need optical drive. I have 7.5" of clearance between the top and middle shelf and 8.25" of clearance between the middle and bottom shelf of this TV stand.
Not very comfortable, no access to heavy workshop.
I'd like to find the sweet spot between loud/quiet while also taking into account cooling/thermal needs. If this is going to be a smaller form, then more heat, no?
None
Win7 64 bit
Within the next 2 months
