sff for high resolution gaming & photo editing
hiptoss
I haven't built an SFF desktop in about 10 years -- shuttle SB61G2, with a radeon 9600pro purchased from zipzoomfly... 'nuff said -- and I would like to move back to that smaller footprint.
1. What will you be doing with this PC?
gaming and photo editing, in that order.
2. Will you be overclocking?
no
3. What's your budget?
$1,500
4. Where do you live? n/a -- my shopping will be done online.
5. What exact parts do you need for that budget?
everything inside the case, including the case: case, cpu, mobo, ram, video card, ssds (2)
6. If reusing any parts, what parts will you be reusing? P
n/a
7. What specific features do you need in a motherboard?
required: raid1
required: >= 2 USB3 ports
8. What resolution output do you need?
2560x1600 (30" LCD) is the screen that I will game from. I also have a portrait mode Apple 27" (1440x2560) for a secondary monitor, but I do not use it for any gaming.
If possible, I want to play games like starcraft2, league of legends, dota2, etc. on max settings @ 2560x1600 with this machine. Is that a reasonable request?
9. Does this system need to fit into a particular space and do you need an optical drive?
There are no special space requirements, but I do need an optical drive. (photos are often given to me on dvds, sadly)
10. How comfortable are you with custom case design/modification and electrical wiring?
No modding
11. How important is the noise/silence of this sytem?
It doesn't have to be silent, but I would like to avoid a leafblower for a pc if possible.
12. How mobile does this system need to be?
n/a, it'll stay in my office.
13. Do you already have a legit and reusable/transferable OS key/license?
I would like to use windows7 is possible, but if not I will buy win8.
14. When do you plan on building/buying the PC?
Within a couple of weeks. I want to give my existing PC to family as a birthday gift just after Halloween.
Get an Intel 4770k for photo editing and a gtx770 for those games. You would need something more powerful for first person shooters, but for the games you play the 770 should suffice
Shuttle are still in business. Look at their Z68 and Z77 and Z87 series. The Z77 is probably your best bet. Your prime difficulty will be ensuring that you buy a GPU that will fit: I cannot spot the maximum length on Shuttle's website.
What size SSDs do you need/want? Do you really need RAID 1 with SSDs, or can you deal with some downtime as long as the data is safely backed up elsewhere?
The minimum size is 256gb, but if I can get larger with this budget then I'm certainly OK with that. :)
I don't "really" need it, as I do have a nas that I backup most of my photos/documents to, and the really important stuff goes to amazon glacier. I do, however, much prefer dealing with a simple RAID reconstruction for most of the probably failure scenarios.
I just don't like dealing with the operating system backups and the frustration that goes into restoring. Perhaps there's a simple-ish piece of software I don't know about that can better deal with some sort of image-based restore over the network?
Would the 770 be fine for FPS, but with slightly lower detailing? I sometimes play TF2 with my friends, and I've been thinking about playing some others with them as well. (payday2, bioshock)
according to this blog there is room for a gtx 770 (EVGA GTX770 2GB 02G-P4-2774-KR) in there. According to newegg, that card is 10" x 4.38". Does that help you in determining which card would work?
Suggestion
CPU: i7 4770 (no need for K model since you're not OCing)
Mobo: mATX boards are cheaper than ITX, but whichever FF you go with, most come with USB 3.0. Try the ASRock H87m or H87ITX
RAM: Corsair, Kingston, G. Skill 16GB DDR3. Go with whatever is cheapest.
GPU: EVGA 770. EVGA just has a better reputation when it comes to customer service.
SSD: Samsung 840 Pro or EVO.
Do you really need two SSDs? Have you thought about using one SSD for the OS, programs and games, and a hard drive for storage and backup?
Decide whether to go mATX or ITX first, then pick out your case.
