sff case with 6800ultra 200w psu question
steve216s
well I'm gana have to put together a mini pc for my trip and a laptop for this price range isnts gana game well,
first question is will a evga 6800ultra fit in one of these cases
http://www.newegg.com/app/ViewProductDesc.asp?description=56-115-017&depa=1
http://www.newegg.com/app/ViewProductDesc.asp?description=56-115-014&depa=1
I think it will but I think the first one will have better cooling I'm gana be using some of my old parts a athlonxp 2000+ and a 40gig hard drive now will that powersuply handle it or should I also get a 250w psu and upgrade it I know I've seen people with 6800gt run on them and overclocked I dont think the amd 2000+ and hard drive should take to much power
what do you guys think
also I'm not shure from the pic but what side is the agp slot on it it on the inner or outer part of the case
after looking at some pics it looks like the agp slot is on the inner side witch should fit a 2 slot card
There's only one single slot 6800 Ultra that I know of.
Its the Asus 6800Us, they also have a dual slot (reference) card which wont work.
http://www.newegg.com/app/ViewProductDesc.asp?description=14-121-175&depa=1 $580 - out of stock! :(
There are several 6800GT's which are single slot, and most 6800nu's are single slot.
P.S. if you're going to put an ultra in a shuttle you need a suck hole like mine: http://www.hardforum.com/showthread.php?t=855304
Also you probably want to remove the rear fan guard with wire cutters (or dremel)
take a look
average shuttle case
agp slot on the outside
biostar sff
agp slot on the inside
my.php
I all ready have a 6800ultra in my current rig and want to bring it with me on my 2 month trip to greece
IDEQs have the AGP slot on the inside, and sometimes a mini pci slot inside of the agp slot. It will fit a dual slot cooler. However, my 200w powersupply in mine was getting flaky with a 6800gt in there, so youll definately want the 250w with the ultra.
that ones to expensive and its for a p4 system I need it to be a amd xp system since I'll be using my old parts for it
but I do think that the agb slot is on the iner side look at the pictures side by side
heres the biostar
and the shuttle
